The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
try going to dewaltservicenet.com and on the left hand side under find parts (small print manuals) type in your model number it will redirect you to the manual/breakdown page. the manual is 60 pages long if you download the complete one. Let me know if you are still having trouble.
Don, I don't know where you might have called but you can download this manual in a couple minutes by going to "dewaltservicenet.com" and on the left hand side type in your model number under manuals and it will redirect you so that you can download. The manual is 60 pages long if you choose the full manual or you can see what language you want and set your printer accordingly. Please let me know if you need more assistance.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom is a box indicating manuals/breakdowns. Type in your model number and you can download one this way.
OK you need to go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number it will take you to another page and then find your type number and click on the instruction manual section on the right side, I clicked on type 2. This manual is about 30 pages long. Let me know if you still need help and if I have helped could you please rate the answer accordingly. Good luck
