If a selfclean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Here is what all your service manual says. Since this is not a generic error hence, no specific fixes available.
Likely Failure Condition/Cause:1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for 30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and close, check with ohmmeter). The Lock Motor may be powered as in above step to open and close Lock Switch. If the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
Hi
I have unplugged the oven for several minutes and the beeping just started again.
there is no door lock lever.
what else should i try.
Hi
I tried unplugging and plugging in again,
now there is an F9 message along with the beeping.
thanks
I really need an answer.
how do I open the locked oven door when an F9 message and beeping are there?
