Wont start
Does the motor turn over? If it does, then you need to check to see if you have spark, gas and air. Check the air filter and replace if it is dirty. If the motor turnes over, remove a spark plug boot from one of the spark plugs and plug in a spare spark plug. Ground the plug on the engine and have some one turn over the engine. Do not touch the plug or wire when the engine is turning over. If there is no spark, I would say that the igniter in your distributor is fried or you may need to replace your plugs. Pull one out to see their condition. If you have spark, then remove the intake on the throttle body. Look down the throttle body and have some one push the gas peddal to the floor while turning the engine over. You should see fuel being injected to the intake. If you do not see any fuel, change the fuel filter if you have not done so recently. If the fuel filter has been changed then I would suggest a new fuel pump.
If the car does not turn over then check your battery voltage. If the battery is dead, it will not start. If you have 11+ volts then your starter is probalbly fried. Hope this helps.
