SOURCE: how big of hole do i need for the mtx 6000 thunder
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
SOURCE: i need to no how
I hesitate to answer this question for fear that you will not like the answer even if it is the truth. I have received a bad rating from a couple of people in the past just because the right answer was not what they wanted to hear.
This is a mono sub-woofer amp, which means that it is already bridged internally. You only have one speaker output in this amp, that means that the amp circuit is bridged inside, it is not split into two channels.
To bridge any output, it requires 2 channels, otherwise there is nothing to bridge.
I have been repairing car amplifiers for over 18 years, and I promise you that there is no way to bridge a single channel amp. Bridging means to convert 2 channels into 1 channel. If all you have is one channel, then there is nothing left to bridge.
I hope this explains it for you, if you have any other questions feel free to post them here and I will answer as soon as possible.
And please do not punish me with a bad rating if you do not like the answer, it is the correct answer, and sometimes the right answer is not always what we want to hear, but it does not make it wrong.
Dave
SOURCE: my friend sold me his subs today and one sub
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
SOURCE: 2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
SOURCE: My mtx ts5510 stopped working
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
Sounds like your Remote wire is way too big. it should be 14 guage. It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires. you should have the power supply wires separate from the Audiop signal wiring. Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
