Hello Doug!
Your pendrive might just be corrupted, as it's not that rare for this kind of devices...
I'd advise you using recovery tools to get your data out of it. Such tools can be:
etc.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Yes the memory is corrupted try to recover it before you format.
once you open the site type in or copy and paste
circuit diagram for scadisk cruzer blade
hope this helps
insert 2 GB USB click start control panel administrive tools computer management disc management you can defragment this USB drive or you can right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files or tick in one box then return after it has fixed the first task then tick the other box
hope this helps
Can you suggest how I might recover the data. ?
can you suggest how I might recover the data ?
thanks doug
