Nova Development Print Artist Version 22 Platinum Edition Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Anonymous
Level 3:
  • Master 492 Answers
  • Posted on Feb 24, 2011
Anonymous
Master
Level 3:
Answers
492
Questions
Helped
142763
Points
1567
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
2helpful
Www novadevelopment com support
Uninstall your current version of Print Artist, and then install it on a different directory. Also, use Run as Administrator when installing Print Artist. Just to be sure, after you installed Print Artist, right-click on it then Run as Administrator to avoid problems with Windows 7.
2helpful
2answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Is Print Artist Platinum Edition version 22 compatible wit Window7?
Print Artist Platinum Edition version 22 is compatible with Win 7.(x86 X64)
You can check this @ Windows 7 Compatibility Center
Hope it helps.
2answers
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
With a Windows 7 operating system, what product can I find that would be comparable to the old Print Artist 8 Grande Suite? Has Nova come up with anything to compare (I've gotten more recent versions and...
Hi Joni703:
I would recomend running your old Print Artist 8 in compatability mode, since you are dissatisfied with the new programs. to do so, install the program on your windows 7 system, if you have not tried already, and right-click on the corresponding desktop shortcut. When a menu comes up, left-click on properties. at the top of the properties window, click on the compatability tab. Next, click on the check box labeled "run this program in compatability mode for:" and pick the system you have used Sierra Print Artist Platinum on previously. It should function normally.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Want to transfer Print Artist 4.0 Platinum by Sierra from old computer using Windows XP to new computer using Windows 7. Each effort results in a window appearing which states "Run-time error "5".
This simply means that your Print Artist program is no longer compatible with Windows 7. Some of the support files that used to work with XP is no longer recognized in Windows 7.
One way to resolve this is to contact or visit Print Artist's developer's website and search or ask for any windows 7 support or patches for your version 4.0
1helpful
Error while installing/ error 1305/reading from file c:\Program Files (x86)\Nova Development\Print Artist Platinum\Layouts\Postcards \GeGeneral Greetings\990Ball & Chain (8386).ppc.lyt. Verify that the...
error's like this are very common and most of the time are caused by microsoft windows updates,go to the site and check first for any updates that need upgrading that don't automaticly update and see what results come up? then you can try and do your install,good luck,garnedd.
Top Nova Development Computers & Internet Experts
NOEL
NOEL
 Grubhead
Grubhead
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
