KitchenAid Pro Line Coffeemaker Coffee Maker Logo
Posted on Feb 23, 2011
KitchenAid Proline coffee maker has what looks like corrosion (bubbling of the finish) near where you fill the water reservoir. Any fix for this or to keep it from spreading?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
225
Points
I have the same problem of corrosion under the finish near the water filling section.
I love the kitchenaid coffee pot. after about 6 months, the water pours out of the bottom of the reservoir when filling it. So, I buy another one. Then after about 6 months, it happens again.
Leaking water from bottom of unit during brewing:
  • Verify that the water is leaking from the bottom of the coffee maker and not just running down the back during filling and pooling underneath. (Look under coffee maker - without lifting - to see if water droplets are hanging from bottom of unit)
Resolution:
If verified that water is leaking from bottom of coffee maker Contact Us for further assistance.
https://www.kitchenaid.com/service-and-support.html
4helpful
We have model # BKC800XL - it give us a message about "descale" not sure what that means and how to correct
Just like any coffee or espresso maker, descaling is a process that needs to be done periodically. If your location has hard water, you may need to descale more often than elsewhere, but it's nothing to worry about. It's just a chemical process that occurs as the result of mineral deposits from the water collecting on the elements inside the coffee maker. I'm sure that coffee manufacturers will sell you tablets for descaling, but I've always just used undiluted white vinegar as the reactant. To do this, I recommend: 1. Empty all of the water from the reservoir. 2. Fill with undiluted white vinegar. 3. For this type of coffee maker, brew as many cups as it takes to empty the reservoir, being sure to dump each cup in the sink as it finishes. 4. Once you've run through all of the vinegar from the reservoir, refill with water and run a few cycles to rinse. (You may want to leave the water to soak for a while to give the residual vinegar further time to clean off the minerals.) 5. Fill again with water and rinse. 6. Once you've emptied the reservoir a second time with the water, your machine should be adequately descaled and ready to brew coffee again!
I actually have the model B30, but didn't see it as an options. My coffeemaker won't brew the whole amount of water in the reservoir, thus making only about 1/3 of a cup of coffee.
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
1helpful
(B30 mini) no water comes out... we have had it for 3 weeks, I have cleaned the needle... and the funnel. Everything goes as normal, the water heats until it is time for the coffee to come out- then the...
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
3helpful
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Runs slow
There is a quick and inexpensive solution to the problem. Household vinegar. Pour about one cup vinegar into water reservoir, replace filter basket without filter allow it to cycle through. After it has finished brewing, you may repeat with another cup of vinegar. Once you are finished running the cycle with vinegar, fill water reservoir with water and cycle through. Be sure to run water through machine at least twice to rinse out all the sediment and or vinegar. Works everytime my coffee maker starts running slow.
2helpful
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
1helpful
Bunn coffeemaker starts before water completely in reservoir
You might try this first. Remove the entire top lid and remove the clear suction cup located near the back of the brewer. Clean this cup with white vinegar and also take your deliming tool and place it in the hole where the suction cup was and clean out. If this does not correct the problem, please call customer service with the model and code date. If your machine is 3 years old or less, we can replace it at no cost. If it is over 3 years old, we will replace it at a reduced price.
2helpful
Need manual for pro 12 kitchenaid coffee maker.
Manuals and guides may be located online at KITCHENAID.COM.
In the upper-right hand corner of the site, click on CUSTOMER CARE and then click on LOCATE MANUALS AND GUIDES.
It will then ask you for your model number.
For an espresso maker, the model number is located on a silver sticker behind the water reservoir. For a coffee maker, the model number is located on a silver sticker underneath the machine.
On the website, type in your model number exactly as it appears on this sticker and click GO.
This will then bring up the literature listing for your particular unit. You will need Adobe Acrobat Reader to view the files.
Also, Kitchenaid Customer Service will send you a physical copy of an instruction manual at no charge if you choose to call them. Their toll-free telephone number is:
1.800.541.6390.
4helpful
2answers
Instruction for proline ce5 coffee machine
I have an instruction manual that I can scan. Email me on [email protected] and i will send it to you.
Steve
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
