Toshiba SD-P4000 14 in. TV/DVD Combo Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba SD-P4000 TV no picture and intermittent audio. Had been fine. Bought Sept. /2004. Perhaps TV life is over? JK
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 23, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470141
Points
19564
HI,
You are correct but it can be fixed actually. The picture problem in your Y Sus and the audio problem is on your audio circuit. You need to decide to repair it or invest for new one.
Regards, Jay
I have just bought a new LG 42LM620T TV. The picture is fine but every so often the sound is a little distorted. It's as though the sound has been recorded at too high a level for the speakers. It
No doubt in the audio menu for your TV there are several tweaks available in there - maybe even a graphic equalizer and perhaps other potential modifications. Access the audio menu with your remote and play around in there. You may be able to soften the audio up a bit. Good luck.
Looking for remote code for toshiba SD-P4000
Hello
Four digit Toshiba remote codes are
[0159 _ 0178_ 0109_ 0120_ 0181_ 0105_ 0049_ 0095_ 0170_ 0260_ 0358_ 0394_ 0924_ 0012_ 0095_ 0117_ 0141]
Three digit Toshiba Universal Remote Codes are
[013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178]
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
1helpful
2answers
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Screen black
press the music mode in ur remote.... video ll be displayed...
1helpful
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
