Well I think the router (Netgear wndr3400) may be firewalling my connections and I need to disable 1 or both. I saw the spec's said dual firewall, I will need to disable both if that is the case
Well, this seems to be an issue specific to the desktop computer. Please disable the firewall on the concerned computer and then check if that resolves the issue.
option 1. check your firewall setting maybe it prohibits skype from accessing the internet. check if you have other firewall programs then check the settings. if it is ok try to disable your firewall. option 2.try if you can use your internet connection without using the router then try using skype. if it works there is problem with the router settings. if not your problem with the skype try to reinstall it.
you might try moving your computer closer to your router make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
Hi, i have the same issue and it isnt the firewall. But here is how to disable it if it is. Go to the router websight at 192.168.0.1 (type this directly into the browser bar at the top of your page. The password is usually password in lowercase. The username is admin. This will get you into the management screen for the router config. Look on the Left and you will see firewall. Click on this then ensure that there are no restrictions for HP.
I still have the issue with the printer so good luck.......scotty
The only option for the 5th pc would be to get it wirelessly connected. You need to install a wireless adapter to your pc. Set the IP & DNS to automatically obtained from router.
You also try to adjust or temporarily disable the your firewall and other securities; Disabling Windows Firewall
Note: A firewall is designed to help protect your computer from attack by malicious users or software. Such software includes viruses that use unsolicited incoming network traffic that infects your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To disable your Windows firewall, please follow these steps:
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In the Control Panel, double click Network and Internet Connections. Then, click on Network Connections icon. 2. Right click on Local Area Network (LAN) Connection on which you want to disable the Internet Connection Firewall (ICF), and then click on Properties. 3. On the Advanced tab, you will see protect my computer or network check dialogue. Then, click on the Settings tab. 4. Click on OFF then OK.
Disable Windows Firewall in Windows XP SP2
1. Please click on Start, then click Run. Then, type in firewall.cpl and then click OK. 2. On the General tab, click OFF (not recommended) and then click OK. I hope this troubleshooting steps will help..if not please notify me
