Sony Logitech Freedom (vs9632830403) Joystick Logo
David Woods Posted on Jul 27, 2008
Logitech Freedom wireless joystick
Hi. I'm running Vista and my joystick named above has no functionality when I try to play an old flight simulator on my laptop. The game is Xicat's F/A-18 Precision Strike Fighter. Is it possible to make these work together? I'm a 45 year old bummed out guy. Thanks.
David
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Mar 03, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
13489
Points
33
I have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
I am playing Flight Simulator X Gold Edition. On my Logitech Attack 3 joystick, what is the throttle control level number? Please help!
I have the same stick, the throttles are actioned by the little levers in front of you at the bottom of the stick, I dont quite understand what you mean by level number...
all you have to do is configure them in the configuration panel of the flight simulator, I use same simulator for practice.
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
2helpful
Combat Flight Simuulator changes Logitech Attack 3 designation
ok go to this site and reinstall the logitech gaming software.
http://www.logitech.com/index.cfm/441/302&cl=us,en?softwareid=3916&osid=13
once on that screen select multilingual 64-bit, this should fix your problem.
Problems with vista
it is better to use windows xp!!! if you are using vista find the name of that joystick!! does your joystick have cd driver?just install the driver!!!
2helpful
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
2helpful
Need driver
http://www.logitech.com/index.cfm/441/286&cl=gb,en?osid=13
There u go M8!
You will find the drivers u need by following that link above.
Thanx for using FixYa
If you find my answer helpfull, please dont forget to vote!
Good luck to you
Nic
Vista
alright i believe i have found a good working vista driver for the logitech attack 3 to get it please follow this link. sure hope this works for you.
if this was not helpful please do not hesitate to re post and let us know.
Regards: PC Pro
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Attach 3 joystick not working with vista
Joystick installed& calibrated but won't work with combat flight simulator.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
