Computers & Internet Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm just looking to update the DGL-3420 and update my DGL-4300 router (they were not in use for the past year) having some connection issues
  • Anonymous Feb 23, 2011
    While updating your routers is a good idea for fixes with manufacturer bugs, an update may or may not solve your connection issues.
    A little more information about your particular issues would help a lot.
    Also, you may find firmware updates at d-links website, as well as a great walkthrough to help you through the whole process. They also have a toll free support number available.
Creative Tech
Level 3:
  • Master 1,719 Answers
  • Posted on Feb 23, 2011
Creative Tech
Master
Level 3:
Answers
1719
Questions
Helped
635994
Points
5906
DGL-3420 Firmware & DGL-4300 Firmware
Please visit the above links from DLink Official Support for your products. Firmware updates, Manuals, trouble-shootong guides etc are available. If you are experiencing connection issues, i would suggest that review the router settings before going for firmware updates. Most of the times the connection issues are due to settings only.
Hope it helps! Good Luck!
CreativeTECH
2answers
How do I get into the routers homepage to change some settings so I can run a wireless internet connection to my laptop while my Playstation is hard wired. I have DGL 4500
To get into the D-Link DGL 4500 router homepage, simply open an internet browser window and type in the following address:
http://192.168.0.1 and press Enter.
When the login window appears, set the user name to Admin and leave the password box empty.
Then, click Login to continue.
Here is the link to the PDF version of the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
I just bought a D link dgl 4500 router and it works fine most of the time. Tonight and one other night before it will reset my wireless network almost every five minuets. I have reset both the modem and...
Make sure you have the latest firmware as this might help with your dropped connections. Also try to make a DHCP Reservation for each computer connected to your network (p. 32 in the User Manual), as that can also help prevent dropped connections.
Download the latest firmware ver. 1.23NA to your local computer. Connect your DGL-4500 router via a wired connection (ethernet) to your computer and install the firmware update following instructions in the user manual.
Firmware link:
ftp://ftp.dlink.com/Gateway/dgl4500/firmware/dgl4500_FW_123NA.zip
Here is the PDF link to the User Manual:
Router not connecting to internet not recognized by Windows 7
Do a manual setup. Look at the instruction booklet and access the router from a browser.
My d link dlg400 router won't issue it's own
The default IP address for this router is 192.168.0.1. Try that. If it is assigning ip addresses to your computer, you can check under status of network connections by right clicking the lan connection, left-clicking status, then click the support tab. The IP address listed next to gateway should be your routers IP address.
2helpful
I have a D-Link DGL 4500 wireless router. I have
If you don't see any devices connected in the DHCP client list on the router interface even when you are sure of the devices being connected, only a firmware update or a re-flashing of firmware can help. You can find the latest firmware available on the d-link support site. You can verify the model and version numbers and download the corresponding firmware. This is only fix.
How do i hook cables to download new firmware into my dgl-4500 from computer to router
  1. I assume you downloaded the newest firmware (version 1.21NA) from this site.
  2. Save or move it on your desktop so it's easier to find.
  3. Connect your router to your computer with an Ethernet cable.(If you're not sure what it looks like, see here.)
Do not upgrade the firmware over a wireless connection!
On the same page, look at the FAQ's. there is an entry called "How do I upgrade the firmware on my DGL-4100/DGL-4300/DGL-4500?" It is a description of the upgrade process itself and will walk you through the steps.
I'm just amazed that they miss a really important warning. Do not unplug your router or close the browser on your computer until this process is finished. This can render your router useless and you will have a nice, expensive doorstop.
When the upgrade process starts, go have a coffee, do your dishes, whatever, but: Leave the router and your computer alone! Wait until the router's reboot is completely finished.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Problems connecting to DGL-4500
This can be a firmware problem so upgrading the firmware of the router should fix this issue on it, so I advice you to upgrade to the latest firmware of your router, you can get it from Dlink web site...
1helpful
2answers
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
DGL 4300
Glad to hear the new one is working (it's likely or at least possible, that the old one is simply mis-configured - resetting back to it's factory defaults and starting from scratch should help with the bridging issue)
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
