RCA TruFlat  27F520T 27" TV Logo
Posted on Feb 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Captions are on ther tv and i cant get into the menu. A message keeps popping up saying blog. fpa escend and i dont know what to do please help
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Feb 23, 2011
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986348
Points
237762
Hello
Just reset your RCA tv by the following method. After reset you have to enter a new parential code and proceed.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the [0] button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
10helpful
2answers
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
6helpful
2answers
A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Menu keeps popping up on screen on 52 r5wh73
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Also double check that the remote is not the problem by removing it from the room or removing the batteries
Let me know if you need more help or info.
2helpful
2answers
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
1helpful
2answers
Cant get the fpa lock off
try checking your manual,that came with your tv.
If not try e-bay for a new remote.
31helpful
8answers
RCA 20F420T FPA lock
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Fpa lock
i need some help people......i need to know how to take off the Lock
2helpful
4answers
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
1helpful
3answers
FPA lock
rca fpa will not trun off plz help me trun it off
i nedd help plz
ty for your help
betty
Giant close caption like screen takes over wphl and sometimes espn
go into the menu with the original remote and turn off ther closed caption.. if your going to tell me you dont have the original remote. Your outa luck then. now miricle cure. Your going to have to spring for the remote. or borrow one from a friend or local store may let you borrow one. Sorry but it is what it is. .. Push comes to shove , go to 1-800-remotes or http://www.remotes.com and buy one. Good Luck
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
