Unless there is some packing material or protective film that you failed to remove it is more likely to be a problem with your home drainage system than the toilet itself.
It could be debris from removal of the previous toilet, a wad of toilet paper or other stuff partly blocking a pipe.
Before doing anything else get outside and open up the man-hole covers. Throw a bucket full of water down and see how quickly it drains away. - if it runs well then the problem is likely to be a blockage somewhere between the toilet and the drain cover.
I would suggest uninstalling the toilet bowl to make access easier then rodding it through with drain rods - you can usually hire these quite cheaply but they are only about £15 - £20 to buy a set in the UK.
