I hope she is alright. Did the switch break into pieces? or she just struck it, maybe moved it a little in place? If you are confiden t enough to remove the switch, do so in order to verify whether or not a wire was jared loose.. Good Luck and be safe, be careful. switch wiring ciukd be HOT Electrically. _Ned
Flip each breaker all the way off and then all the way back on.. If that doesn't fix the problem, look for a tripped GFI (go around and press the reset button on any outlets that have the buttons "test" and "reset"). If that still doesn't work, you should probably contact an electrician.
