Televison & Video Logo
Posted on Feb 23, 2011
V-Chip locked on Polaroid 3700 model, asking for password but never set one up. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
220
Points
7
Use the V-CHIP function, must enter a four-digit password. The factory password is
0000.
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 • Televison & Video
Polaroid 3700 tv won't turn on no standby lights or anything
Check for any loose contact with any of the connection sockets at the power board, to main board. Re-seat them all once and check. Contact any service technician. Gopakumar Gopalan Google
Samsung password reset
Im assuming its a samsung phone
Samsung cell phones come with many security features.
In addition to the common feature of preventing calls after a period of inactivity, some Samsung phones also allow you to prevent others' use of your phone's SIM chip and access to your files.
One password unlocks the various locks, except for two other passwords used for the SIM chip. The syntax of the menu items to click to reset a password differ somewhat between Samsung models but you can figure out roughly how to apply instructions for one phone to another.
Lock the phone from making calls by clicking "Start" or "Menu," "Security Settings" (or "More" and then "Security"), and "Phone Lock" or "Device Lock."
Change the password by clicking "Start" or "Menu," "Security Settings," and "Change Password." Then enter a new password.
Set the phone to work only with the current SIM chip by clicking "Menu," "Security Settings," and "SIM Lock."
Enter a new password when prompted.
Prevent unauthorized use of your SIM card by clicking "Menu," "Security Settings," and "PIN Lock." Type a new PIN when prompted.
Prohibit access to your files, messages and contact list by clicking "Menu," "Security Settings," and "Privacy Lock."
Enter the password from Step 1 when prompted to unlock access.
Reset the file lock/messages/contact password by resetting the phone lock password, as in
Step 1
Password lockout on new polaroid tablet
Depending on how this tablet is set up you should be able to access the factor hard reset on bootup. You'd have to look up the specific key sequence? to do it.
98helpful
10answers
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
2answers
Need a password for my TV.(Polaroid) I never remember putting in a password on Tv. Now I have programs lock-then it says program locked enter password. I can't rememeber a password. Can you help me?????
Polaroid sets a defualt password for the V-Chip at the factory. The default is 1111, as listed on page 21 of the manual. I would recommend you either change the password to one that you'll remember, or disable the V-Chip entirely.
What is the v-chip code for polaroid tv
Parental
DVD discs equipped with the child lock function are rated according to their contents and settings vary from disc to disc. Depending on the disc, you can lock out selected scenes or playback of the disc altogether. Access parental control by pressing the left/right (direction buttons together) on the remote control and then press the OK button.
System Setup/Password
Parental control features are password protected. The original setting is unlocked. This setting allows you to use number buttons to input any password. Note: The Default Password is 1369. This password is always effective even after you
have selected your own password and changed it. To avoid the possibility of others using the default password to set the parental level and change the password, you can record this default password in another area and delete it from this manual. Some discs can be limited depending on the age of users while some discs cannot.
Manual is here
http://www.polaroid.com/service/userguides/ce/under_cabinet_lcd_tvs/fdm0700a_ug.pdf
(you need Adobe Reader) and their phone # is
at the end!
Default accidentally pressed and v-chip locked programming
What you want to do is contact Polaroid Customer Support and tell them the situation and they will give you a factory default code for the v-chip. The Polariod C.S. # is 1-800-605-5364. They should be able to help you without any problems. Hope this helps...
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
