Generac Guardian Model 5784 20 Kw Generator 200 A Xfer Logo
Posted on Oct 21, 2017
I have a Generac Guardian 20kw air cooled standby generator. I recently replaced the battery charger as the battery went dead a few times over the last several months. Upon replacing the charger, I now have a red led indicator light and the unit will not crank. Alarm log does not identify the problem. The 7.5 amp fuse is good. Any Ideas?
  • 1 more comment
  • Anonymous Feb 23, 2011
    How old is the battery ? Do you have a multi-meter with which you could test the battery voltage ?
    Charlie
  • bdaddy1 Feb 23, 2011
    Battery is two years old. I recharged it and the volt meter shows 12.5
    Try cleaning all related male
Antero Tikkanen
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Oct 24, 2017
Antero Tikkanen
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
20839
Points
57
The battery could be bad. Try to measure the battery voltage when you try to start. If the battery is bad then the voltage will drop quite low when the battery is loaded with trying to start the set. If you can borrow a similar battery you could just try with it.
2 Related Answers
mycharmingli
Stormi Paulk
  • 415 Answers
  • Posted on Nov 07, 2010
SOURCE: battery does not stay charged on my 20kw generac
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
jdthefixer
  • 747 Answers
  • Posted on Jul 07, 2010
SOURCE: 2nd battery explosion with 3 year interval of flawless operation.
If the unit is using a wet cell acid battery, it's possible that dirt mixed with hydrogen build up on top of the battery caused the second failure. The battery top should be kept clean and should be checked at least 4 times per year. Any stray ignition source can cause the hydrogen to explode, including lightning.
It's also possible that the battery float charger needs to be adjusted or possibly has a problem. Some float chargers are adjustable. The higher the charging rate the more off-gassing the battery will experience and increase the chance of a failure.
If the battery has exploded, the entire generator and housing should be cleaned (washed) thoroughly to remove any remaining battery electrolyte (acid).
Be careful - if you aren't comfortable working on this type of equipment, it's best to call a local dealer and find a service vendor.
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Generac troubleshooting
Your battery is dead..If the controller has a visible display your battery charger is most likely OK. Just put in a new Group 26R battery and set the time etc.
Have air cooled 20kw generac cranks but does not start
THERE SHOULD BE A LOW OIL SENSOR ONTHE SIDE OF THE MOTOR PLEASE MAY CAUSE THE MOTOR NOT TO START YOU SHOULD BEABLE TO JUMPER THE TWO WIRES ON THE SENSOR AND SEE IF THE GENERATOR WILL START
Have a generac generator 20kw air coolded, automatic standy model 60511 that the battery goes dead all the time
how old is the battery? charge the battery then remove the negative cable place a test light between the battery and cable if the light is on you have a draw unplug things til the light goes out thats your draw
1helpful
Generac Model 5525-1 20kw air cooled standby generator Question: How do you access the battery? I think it is behind the front panel, but can't readily see how to open/remove the front panel. Thanks!
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
2helpful
Battery does not stay charged on my 20kw generac generator
4helpful
Generac 20kw - new battery dead, twice. is there a problem?
if this is a standby unit. there is a charger built into the control box. check the fuses. if it still blows the d\fuse you can install a float type charger available from most auto parts stores. make sure there is power comming in from the bldg breaker box.
Top Generac Guardian Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
