Question about Maytag MMV4205 Microwave Oven
Display not workign
Our over the stove microwave oven displays the clock clearly, but the timer display has been dimming steadily over time and now is barely readable.
  • 1 more comment
  • gooftroop6 Jul 27, 2008
    On closer examination, the clock is also so dim as to not be readable....??
  • gooftroop6 Jul 28, 2008
    The display problem involves our Maytag model MMV4205BAW, serial #10004439JA. The scrolling banner display is brightly lit and easily readable. The clock and time part of the display is so dim it is no longer readable unless the kitchen is completely dark. Any assistance is greatly appreciated.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
    In a few cases, we can replace the VFD tube, but in most cases the entire control board would have to be replaced.
    But once we get the brand and model, we can tell you.
  • Maytag Master
  • 9,156 Answers
Sadly, the display tube is not available separately, so the only way to fix this is to replace the board, at a whopping $181.48!
One trick that helps is to remove the control panel assembly, take the circuit board out of the frame and very carefully wipe the front of the glass and the rear surface of the control panel frame's display window.
Use a soft cloth with alcohol-based (non-ammonia) window cleaner.
That will brighten it up quite a bit.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Be sure to unplug the oven before you do any disassembly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE:
Microwave model RMV320SS clock/timer light dim
For Viking RVM320SS, that would be a fault in the backlight circuit.
If you're in the US or Canada, I regularly repair and upgrade these with the aim of correcting and preventing display errors. For details, feel free to contact me via my site below.
Always include your FULL model number*, FCC ID number*, and detailed symptom information. * from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 20, 2017 | Microwave Ovens
How to fix display on Clock/timer? It has become too Dim and you can't see it during the day, only at night when it is dark.
The same happened on my oven. The only remedy is to change the display unit. A fairly simple job if the part is available, but best to weigh up the price and cost of repair versus a new oven.
May 24, 2015 | GE JVM1790SK Convection/Microwave Oven
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
How do you reset the clock on the microwave
press clear, press clock, enter time, press clock again.
Dec 09, 2009 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Maytag MMV4205 Microwave Oven Logo
544 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
