The green plug is for sound OUTPUT (to speakers with an amplifier), the blue is for sound pre amp INPUT (like a MP3 player or a any other device like an old 4 track casset WALKMAN player) the pink one is for a MICROPHONE INPUT, the black is for a surround system OUTPUT, and the yellow is for a digital OUTPUT all for a surround 5.1 system, so you have to look closer you will notice some difference in the icons stamp in the back, green has a sound wave symbol with an arrow going outwards the pink one has a sound wave symbol with a MIC symbol, the blue has a sound wave symbol with an arrow going inwards, the black and the yellow has a sound wave symbol with a digital symbol
conclusion... you can use the green OUTPUT to feed to one amplifier, if you want to feed music to multiple amplifiers you need a SOUND MIXER with at least two outputs, you can buy a chap sound mixer for about 20$, go to your local electronic store and EXPLAIN EXACTLY WHAT YOU WANT TO DO and they will sell you exactly what you need...
Hope this helps!
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
