SOURCE: htc tytn 11
I will assume you bought it on Ebay or the Internet somewhere from the text you say is on the screen.
There is a possibility you have lost the information on the phone and will need to reinstall anything you have added to it since you bought it, but possibly not.
First thing to try is what is called a "Soft Reset". If you have not already done so, take your stylus and press it lightly into the small hole in the bottom of your phone until you feel a light click. Your phone will restart. If it boots up normally, then you are done, and everything is roses again, and your information should be in tact. Yea!
If not, then you would next try a Hard Reset. This step erases any information you might have added to the phone since getting it and puts it back to the factory defaults. There are two buttons below the screen that when working normally say "Calendar" on the left, and "Contacts" on the right. You need to hold both of these buttons down then insert your stylus into the reset hole at the bottom of your phone. You should get a screen saying "Press SEND to restore Factory default. press END to quit." Go ahead and press the Green Send key. Wait for the phone to reboot. Hopefully at this point your phone will be at the initial setup screen. If it is, follow the directions on the screen to finish the setup.
I realize this is not your phone, but the button locations are the same, and the screen should be similar.
Soft Buttons just above Send and End, and Reset Button :
Reset Screen:
I hope one of these work for you. If not, don't panic yet. There are still other options... Let me know how it turns out.
SOURCE: My HTC TYTN11 shows red green white etc colors when switched on
the tricolor screen means your device is on bootloader mode.
this mode is for reflashing your device OS.
if you entered this mode accidentally, you might try to release your device's camera button. Since the factory setting to enter bootloader is reset button+camera button from standby mode.
try to get battery out and release the camera button. many times happens that this button get stuck inside, because it's not a button you use many time and it get fully of dust.
SOURCE: I have a htc raph800 touch pro The screen
You are welcome, glad to know that it is working now.
SOURCE: htc herm200 can't charge
Hold down the two soft-keys (the ones below the screen) and while
you have them held down you poke the reset button with your stylus.
You'll then see a message on the screen saying 'press R to reset, X to
exit'. Pressing the R key on the keyboard will hard-reset the device.
It'll now take a few minutes to reboot and load all of the operator
customisation etc.
This procedure will hard reset the HTC TyTN, Vodofone v1605 and all other HTC Hermes variants.
PC suit for HTC F3188 you can download here-http://www.htc.com/www/supportdownloadlist.aspx?p_id=311&act=sd&cat=all
1. Download the PC suit .
2. Double click the exe file to run it.
3. Follow the instructions given to you.
4. When installation has completed, the program will open and you can connect your HTC F3188 without any problem.
software112.com/products/htc-pc-suite.html
you can download the pc suit in www.htcmobile.comin this website search your model and then download the pcsuit.
http://www.avaxdownload.com/352/dl/Free+Htc+Smart+F3188+Pc+Suite+Download.html
Good Luck.
Source: i need pc suite for
