1998 Volkswagen Golf Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1998 VW GOLF GL 1.6 AUTO Problem: I would be grateful if someone could advise. The problem started with engine stalling at junctions & traffic lights. Over few months took it to local garage to get throttle body cleaned, fuel filter replaced, air filter checked, MAF sensor checked, but problem became worse with engine cuting-off frequently & doesn't fire unless car left for 4-5 minutes before re-starting. Took it to garage again, the mecanic mentioned that nothing is reported after checking VAM-COM. Presently it's been reported that mechanic can't see any spark or fuel to engine even after changing fuel pump relay, coil pack & battery. The starter works fine & lights come on as normal while starting, but engine doesn't fire. Please advise. Many thanks
Anonymous
Level 2:
New Friend:
  • Expert 127 Answers
  • Posted on Mar 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
127
Questions
0
Helped
35724
Points
391
Sounds like fuel pressure problem, pressure reg. problem. Clean connections on AAT located on air horn
VW GOLF MK4 1999 WHERE DO YOU PUT TRANSMISSION FLUID
you need a special tool or take the car to a shop
Im thinking about buying a 1997 vw golf gl, guys says he's replaced the clutch once and still has problems, also he says the car wont start without fixing the clutch first. could it also be an el
I have no idea why your even asking any questions
about that VW
Replaced the clutch & still has problems---so you want to
buy someone elses problems?
Car won't start-- so you can part with your money & get
a car that you can't even start?
Could be electrical or something?
Your going off what the owner said---Ya & why is he
selling it--because he can't afford to or figure out how to
keep it going?
I know money may be an issue but you don't buy a 16 year
old car regardless of condition ,not even if it was free ,I wouldn't
take it.
Do you know anything about VW's or have a college degree
in automotive technology?
2answers
Volkswagen golf 2.0 tdi service manual
1993-2005 Volkswagen Jetta, Golf, GTI, Cabrio (A3-A4) Hatchback & Sedan Workshop Repair Service Manual - 350MB PDF
1993 2005 Volkswagen Jetta Golf GTI Cabrio A3 A4 Hatchback Sedan...
This is a COMPLETE Service and Repair Manual for your 1993 1994 1955 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 VW Jetta, Golf, GTI, Cabrio (1.8L turbo, 1.9L TDI and PD diesel 2.0L gasoline, 2.8 LVR6) (A3, A4 Platform) Hatchback & Sedan. It covers every single detail. All models, and all engines are included.
This QUALITY manual is 100 percents COMPLETE and INTACT, no MISSING/CORRUPT pages/sections to freak you out! Detailed illustrations, exploded diagrams, drawings and photos guide you through every service repair procedure. This manual can be viewed on any computer, as well as zoomed and printed. All repair procedures are covered A-Z. This manual for VW Jetta, Golf, GTI, Cabrio makes any repair job easy to do with very easy to follow step-by-step instructions & pictures on all areas of repair.
Format: PDF
System: All Versions of Windows, Mac, iOS, BB, Android, etc..
Requirements: PDF Reader.
Printable: Yes
TABLE OF CONTENT (example)
GENERAL INFORMATION *
ENGINE *
engine mechanical
engine lubrication system
engine cooling system
engine control system
fuel system
exhaust system
TRANSMISSION/TRANSAXLE *
clutch
manual transaxle
automatic transaxle
DRIVELINE/AXLE *
front axle
rear axle
SUSPENSION *
front suspension
rear suspension
road wheels & tyres
BRAKES *
brake system
parking brake system
brake control system
STEERING *
power steering system
steering system
RESTRAINTS *
seat belts
supplemental restraint system (srs)
BODY *
body, lock & security system
glasses, window system & mirrors
roof
exterior & Interior
Instrumental panel
seat
AIR CONDITIONER *
air conditioner system
ELECTRICAL *
wiring diagrams
starting & charging system
lighting system
driver information system
wiper, washer & horn
body control system
lan system
audio visual, navigation & telephone system
auto cruise control system
power supply, ground & circuit elements
MAINTENANCE *
maintenance
INDEX *
alphabetical Index
1helpful
I have a 98 VW Golf (ABA engine) it keeps stalling at idle. I saw that it might be the mass air flow sensor, so I unplugged it and it smoothed out and ran great. I replaced the sensor and it still stalls....
Try cleaning throttle body with throttle body cleaning fluid. You can pick this up at any auto supply depot. Just follow the instructions on the spray.
2helpful
98 VW Golf GL, Dashboard lights out!
Remove dash and make sure main electrical plug is snapped in place .Also look for a lose ground wire.
2003 VW golf o2 sensor?
Yes, it could be something else, other than the converter, such as a faulty o2 sensor. Take your VW to Autozone or Advance auto, and ask them to a do a scan, to see what they come up with ( think it's free).
1helpful
Vw golf 1.4 2002.diagnostic fault codes;4076 temp
The parts aren't really that expensive, it's the labor these places charge an hour. Call around and see who can do it the cheapest, unless you want to do it your self.
N reg vw polo engine cuts out at junctions when headlights are on
first clean throttle body out with carb cleaner and some clean cloth , if the throttle flap is dirty the car will stall
4helpful
5answers
VW Golf MK3 1996 P - Car cuts out when slowing down. Battery and Oil lights come on. Restart the car then starts juggering. Its not a fluid purring from the engine.
i would start by cleaning out the throttle body. they collect soot and not have to be a lot either for it to mess up the idle speed, i had trhis on mine soon as i dipped the clutch to slow down the rpm dropped to about 400 to stall, i cleaned throttle body out ( taking air intake off and wipe round inside and the butterfly will be enough) and now it idles and the rpm dont drop below 900
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
