yes, it is possible. You will connect the earphone jack from your voice recorder to Mic of your laptop. Then you will be needing a wave software on your laptop, download the wave software from the internet, open the wave file, then press play on your voice recorder and the minutes will be recorded into your laptop as a wave files.
But the easiest method of tranferring the minutes is by using the usb cable of your OLYMPUS VN-480 PC voice recorder. If you don't have it you can purchase it, then connect it from your OLYMPUS VN-480 PC voice recorder to the usb of your computer and it will be read like a flash drive.
After that, go to my computer and you will see a drive representing the OLYMPUS VN-480 PC voice recorder, open the drive and you will see your minutes, then simply create a folder on your computer, and copy, paste the minutes into the created folder. And the would be all.
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
if the power is interupted or improperly unplugged from the computer, the files may be corrupted... try to play the files and while playing move them to another folder... this may get your files back... else you will need to clear the recorder by pressing stop and erase at the same time for about 3 seconds.
How are files erased from the VN-3100PC? Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
Press the [REW]or [FF] button to select the file.
Press the [ERASE] button.
Press the [REW] or [FF] button to select YES.
Press the [PLAY] button.
To erase the contents of a folder:
Press the [REW] or [FF] button to select the folder.
