SOURCE: our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
SOURCE: xerox workcentre 7328 fault code 062-393
This is a document scanner problem, probably a bad circuit board. (This PN may be 960K00442 but that needs to be verified in your unit)
Short of that, you could reinstall the "IIT software".
A technician could reseat the EEPROM on the IIT board which controls the document scanner. He should also reseat the scanner bar and cables underneath the glass.
Whit
Item, Inc
SOURCE: My Machine Xerox Workcentre 7328
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
SOURCE: XEROX WORKCENTRE 7328 IS RUNNING
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
