Ndobbins
Do you getting anything on your screen when you first turn on your computer. This will tell me if the problem is with the video card or something else on the computer.
Also what kind of monitor do your have CRT or LCD. If LCD do you have an old CRT that you can connect to the computer for testing.
Also does the computer sound like it is booting normally or does it not seem like it is booting up.
Issken
http://www.fixya.com/users/issken
Noah
Ok since you can get into the Bios we know that the video card is some what working. So at this point it sounds like you may have a driver problem with the video card/monitor drivers.
I ran into this the other day when I had a computer on one of my work benches with a CRT testing the computer. When I booted up the system it came up in standard VGA 800x600 with an error that there was a problem with the video card drivers. After I reinstalled the drivers for the video card the LCD worked fine.
The reason for this is LCD monitors are really picky on the signal that you send to them. So if the refresh rate gets off then monitor will turn off. In your case most likely with the EMachine it is set to quick boot so you never see any of the pre-boot info and all you get is a blank screen.
Now if you do not have access to an CRT monitor (it you are a tech it is a good idea to have one for these cases) you may be able to try to install another video card to see if this will force Windows to update the video card drivers. Also another thing you can try is to pull your hard drive and do a fresh test install of Windows to see if the problem is actually with Windows or the card its self.
Let me know if you have any more problems or questions
Issken
Noah
Unfortunately if you have gone through what I have suggested and still have trouble then this means that you most likely have trouble with the motherboard.
Let me know if you have any more questions
Issken
Nothing comes on screen as it boots up, you can go into the bios but it wilo not go into windows it beeps ,harddrive spins up, but no video, i'm a computer tech but this sucks.
Noah
Nothing is workling i think maybe the motherboard or cpu is bad memory checks out fine,what do you think i have 2 computers doing the same thing emachine blues........HELP
