Question about Polycom ISDN BRI Cable (2457-08341-001)
Your call could not be completed because the call was routed through an intermediate network that does not service the far site. contact your network administrator for assistance
Mostly generated due to a firewall configuration issue.
The problem is to identify which firewall needs adjusting; the one at your site or the one at the other site (be persistent, the other site usually claims that their configuration is correct *wink*).
A good list of needed ports for videoconferencing can be found here:
http://www.c21video.com/firewall.html
Posted on Nov 07, 2012
    Master:
  • 713 Answers
Dial area code first then try to call some one.
Posted on Feb 22, 2011
SOURCE:
What is the difference between VPN-connection and Proxy websites?
While both a Proxy and VPN service will re-route your internet traffic and change your IP, they function slightly differently.
Think of a Proxy as a Web Filter. The proxy settings are applied to your internet browser whether you're using MSIE, Chrome, Safari, Firefox, Etc. When browsing the internet through a proxy server, all benefits with that server are used, for example, (Security, Speed, and Geographic Location). The proxy will only secure traffic via the internet browser using the proxy server settings.
Unlike a Proxy, a VPN service provider(Virtual Private Network) encrypts all of your traffic, replacing your ISP and routing ALL traffic through the VPN server, including all programs and applications. This also will use all benefits of the VPN server such as (Speed, Geopgraphic Location, and Security).
The VPN can be easily connected or disconnected with the click of a button.
In conclusion, a proxy server is completely browser based, and is not as compatible with certain web pages that use non-browser technology such as: Comedy Central,Zatoo, Fox OD, and Sky Player. However, a VPN will work with ALL internet based services, but will offer less choice on which applications will get run through your ISP, as with the VPN, everything is routed through that server when connected.
So, you can get VPN services from sources like HideMyAss, Super VPN, etc., Once you have enabled a VPN service, you can visit IP-Details.com and have an IP lookup to ensure the change in your IP address.
Jan 21, 2015 | Computers & Internet
How do I program a route on a nuvi 40
only point to point routes on this model. You can just add some intermediate points if the route is active
Sep 16, 2014 | Garmin Nuvi 40
Speed test through the modem gives proper results. Connect a Fortinet 110c IPsec VPN and speed is tremendously slow
VPN connections are encrypted, this adds extra overhead to the connection and an extra place all data must route through.
Once connected to a VPN your speed is determined by the slowest connection between you and your end point (The site you're visiting, or the service you are using)
For example:
If your home / business connection is a 20mb but your VPN is a 1MB connection, then your speed is going to be less then 1mb once you connect through the VPN.
Encrypted traffic is usually a bit slower, however if you feel speeds are far slower then they should be, you will need to contact the vpn service provider and see if any settings in your VPN software can be changed to speed things up.
Dec 26, 2013 | Fortinet, Inc. FortiGate 110C (FG110CUS)...
What is routing loop?
A routing loop is a condition in which a packet is continuously transmitted within a series of routers without ever reaching its intended destination network. A routing loop can occur when two or more routers have routing information that incorrectly indicates that a valid path to an unreachable destination exists.
The loop may be a result of:
Incorrectly configured static routes
Incorrectly configured route redistribution (redistribution is a process of handing the routing information from one routing protocol to another routing protocol and is discussed in CCNP-level courses)
Inconsistent routing tables not being updated due to slow convergence in a changing network
Incorrectly configured or installed discard routes
Jun 07, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
Mary.farnerI LOST MY MANUIL! NEED TO TRUN IT OFF AND ON
Turning On: Press the On/Off Button for aprox. 2 sec. Both icons will flash intermediately to indicate the headset is powering up.
Turning Off: Press the On/Off Button. When both icons flash intermediately and then go out, the headset is off.
For a complete guide or to see the full user manual try this site...
http://www.jabra.com/Sites/Jabra/na-us/Headsetsupport/Pages/JabraBT2080.aspx
Aug 16, 2010 | Jabra BT2080 Bluetooth Headset
Client can not surf or ping specific web address - Cisco router
I am not sure but I believe the IP address is not correct. The trace goes to the following address:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Tracing route to 200-100-1-5.dsl.telesp.net.br [200.100.1.5]
on my machine. This is only a service provider I believe and not an end website. Have you checked and verified the ip address with the contact organization? Just because you can run a trace route on an ip address does not make accessible.
The cisco could also be blocking the outbound connection at your end.
Hope this helps.
Feb 11, 2010 | Cisco 877 ADSL Security Router
How do I set an intermediate stop garmin 750
the term is waypoint and these can be set up in your route from the menu screen
Aug 14, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Switch to Switch Connection
This is a very specific problem that requires a site visit to solve, there are many factors that can effect the transmission of data over a run of that length. There are many solutions to this problem, they range from rerouting the cable run to avoid sources of interference to selecting another medium such as WLAN or IrLAN. The specific implementation of the solution must be custom tailored to the situation, sometimes the solution requires equipment that is readily available on a store shevle and sometimes the solution must be engineered to accommodate the needs.
I would recommend looking at the cable route to see if it runs past any major interference makers (copiers/large office machines, industrial equipment, power equipment). Then look at the possibility of an intermediate repeater/router (protected location and availability of power outlets). Another possibility is a wireless technology, the specific technology depends on many factors. If you need high speeds or large data transfer, perhaps an Ir (Infra-red) link or WiMAX (802.16) would be best. If general purpose network connectivity is needed, then a standard 802.11 a/g WLAN will suffice. I recommend that you contact a local networking firm for a detailed consultation. Another resource that might be a better fit for most small budgets will be to contact the local college/university that has a well defined IT program to solicit members of the Alumni in a networking degree field.
Jan 06, 2009 | D-Link Computers & Internet
Open Questions:
See all Polycom ISDN BRI Cable (2457-08341-001) Questions
Polycom ISDN BRI Cable (2457-08341-001) Logo
6,110 people viewed this question
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
