Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
I have a shoe lace wrapped around the agitator how do I take the agitator off?
  • jjonson25 Feb 22, 2011
    Yes it was an option. thank you
    Master:
  • 713 Answers
Get a long sharp nife and cut off.
Posted on Feb 22, 2011
SOURCE:
How do i tie my shoes?
I am trying to understand the problem here. Nike shoes that are equipped with laces are usually sold with some. If the laces are broken, you can get more at a shoe repair shop. If it is for disability that you ask, then the occupational therapist may not have given you the techniques you need yet.
Apr 10, 2015 | Nike Clothing Accessories
Tip
Tips on how to Choose Wear and Care for converse all star shoes
Buying Converse shoes is quite simple. Make sure one's just like the other, from the way the toe guard sits on the shoe to the distance between the eyelets. Check to see if the tongue pokes out about an inch over your laced-up shoelaces on each shoe.Here are some tips for wearing your converse shoes: •Wear quality socks that allow your feet to breathe.•Keep your laces untwisted within the eyelet space so they'll last longer and look fresher. •Make Converse your own by choosing laces in a different color or size. •Center the tongue of the shoe so they'll be more comfortable on your feet.•Make sure to confirm that wearing Converse will not create or magnify any foot problems. Bunyons, pronation, supination will all lead to more serious problems and later it will be harder to find shoes that fit and feel comfortable. When caring for your Converse shoes, just say no to bleach! Use soap and water to clean shoes without damage.
on Oct 27, 2010 | Clothing Accessories
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
Jul 27, 2014 | GE GTWN3000MWS Washer
My moccasins shoe lace came undone how do i fix that
You can replace the lace and then tie it up to keep it from falling off. Leather thong laces are likely the best choice because it will look close to the original.
Apr 12, 2014 | Clothing Accessories
Shoe laces are weak
You dont give me much information. Are the eyelets OK? If not, they can rip the laces. Get nylon laces and they are stronger than cotton.
Mar 17, 2014 | Clothing Accessories
My mukluks keep slipping and falling off at the heels
Do they have laces that you can tighten the laces over the arch? This can help more than tightening the laces at the top.
Jan 25, 2014 | FITFLOP Mukluk Shoes for Women
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
Just bought new balance wr 859, having pain of top of foot (where bump is) seemingly from the tight lace, however when loosen the lace, sneaker is too big. thank you ege972@aol.com
Have you considered tongue pads? They are soft cushions with felt on one side and adhesive on the other that you can stick to the tongue of your shoes to provide cushioning and reduce slippage & pressure from laces on your instep.
Some options are available on the site below.
http://www.feetrelief.com/feetrelief/arch_support_accessories.htm
http://www.wardrobesupplies.com/store/m2_footcushion.html
One thing you might want to consider is if you have a high arch to your foot. Generally, the higher the arch, the higher the instep which will effect the way shoes fit you. The shoe that fits comfortably over your instep without causing pressure may then be too loose around the heel. Runners with high arches also experience more foot pain/strain because their feet actually fall harder than a lower arched runners. You may want to consider the Nike Pegasus or Adidas Cushion if you think this is the case.
I really hope this helps you.
Nov 17, 2010 | New Balance WR859 Running Shoe Powder 13 D...
Brush will not rotate. Have replaced both belts. Self propeled windtunnel model
you might need a new agitator (brush). if you caught something on it like : shoe laces, socks or anything that stops the brush. you should see on the brush were the v-belt goes burn marks or even gashes. this is a indication that you need a new brush.
Jul 19, 2009 | Vacuums
I have a LG front load washer, and a shoe lace got stuck in the little holes on the back. The end of the shoe lace is made of some hard materials and it gets bend, so got stuck in the little hole. I...
Ouch! I'm guessing that the shoe lace wrapped around the shaft from the inner tub and cannot be pulled back into the wash tub. That sucks, because the only way to get at it then would be to remove the motor rotor, sepperate the two halves of the outer tub, allowing the inner tub to be removed to access the offending shoe lace. If you know what you're doing, it's about a two hour job. My advice: Just live with the noise. Please don't bother rating this, as anything but a Fix-Ya drops my score.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
345 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
