iiyama Vision Master Pro 455 (Beige) 19" CRT Monitor Logo
Bjorn Sammut Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a problem about iiyama Vision Master Pro 455 19" CRT Monitor. This week I was using it and the picture comes small and then it comes like it was all the time. It spend all the day doing that. Then the day after I started the pc and turned on the monitor and the picture didn't screened up, the orange led on the monitor flickers off and then back on, every second. I check the wires and everything and I found that the fuse in the plug was not placed properly and it was sparking. Then I replaced the wire completely and the led remained flickering. I opened the monitor and found that the board is a bit dark (I think the temperature rised a bit) and the soldering iron of some components wasn't properly in contact with the board. Then I soldered them well. When I tested it, it remained with the same problem. It looks like the picture will come but it won't... What could it be? Can it be the tube is gone? Or something like a regulator is not working well? Thanks in advance
Anonymous
Level 3:
Master:
  • Master 713 Answers
  • Posted on Feb 22, 2011
Anonymous
Master
Level 3:
Master:
Answers
713
Questions
0
Helped
107018
Points
2162
Your pitcher in moniter is going bad replace moniter.
Have owned a iiyama 17" pro crt for a few years,
These were a fine monitor and with the kind of image quality you cannot get on TFT's.
If you know the graphics card you are using is working ok, have checked the VGA cable connection and socket at the monitor and computer and have tested the monitor on another computer, that would rule out any problems as far as connected devices are concerned.
The problem you describe, and it is unusual that it has happened so quickly, points to a failure of the monitor internal board. You may be able to get this repaired at a reasonable cost by seeking the opinion of a TV repairman, who might be able to fix it.
1helpful
Windows 7 doesn't recognize my iiyama Vision Master Pro 450 Monitor, what to do?
My Iiyama Vision Master Pro 450 works with Windows 7 when connected with a VGA video cable that has 5 BNC RGB connectors that attach to the back of the Iiyama monitor. No driver install was needed; Windows 7 shows my Iiyama monitor as a "Generic Non-PnP Monitor" with 1024x768 resolution.
1helpful
Iiyama Vision Master Pro 454 (White) 19" CRT Monitor Problem Now! cant find driver download for relisys
If you want a Iiyama driver go to the Iiyama website, follow links for support and downloads.
If you want a Relisys driver, go to the Relisys website and follow links for support and downloads.
2answers
19" Iiyama HM903DT A Vision Master Pro 454 not detected
Try downloading and installing drivers.
I found some here:
http://www.howtodrivers.com/model38655.html
Iiyama HM903DT - Stopped switching on - constant orange standby
The way I solved it…
I received from iiyama a quote for repair: 400€ without VAT, 478 € with VAT, with a 3 month warranty.
So I ordered a HP LP2475W H-IPS LCD monotor from HP, for 656 € VAT & delivery incl. And a 3 year ON SITE warranty. It is superb, and after calibration it largely outperforms what I had before for my photographic use.
Hope this will help…
2answers
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
Worldvet
1helpful
Iiama vision master pro 511 MA201D - horizontal distortion adiustment
FACTORY MODE:
Turn ON and OFF the Power Switch while pressing the MENU Button. Turn ON the Power Switch again while
pressing the – Button and you are in the Factory Mode. The following menu appears on the screen when you
press the MENU Button. Turn OFF the Power Switch to exit
Iiyama HM903DTA 19" Vision Master 454
I would suspect it needs to have electronic troubleshooting done in the power supply section to find and replace the defective components.
2answers
Compressed Screen
if you get a video camera & wave it from left to right while pointing it at the screen you'll just see the image in the flicker
Top iiyama Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
