Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
watchband is too small for my wrist . I need an extra link. How do I get one?
