just copy your contacts or move your contacts from your phone memory to sim card memory from Contacts setting menu. and paste it on any other IOS or android drive and import contacts. then again put your sim card in flip phone and first empty the sim card memory and repeat the same procedure;
Anonymous,
How do I import my contacts from other accounts?
You can import your contacts from other accounts (ex: email, Skype) from the friend requests page. Once you've imported your contacts, you'll have the option to add each contact as a friend.
To import your contacts:
*Enter the code: *#7370# and press Yes to confirm initialization. *Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) *To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: *on/off + * + 3 *Before making a Hard reset better backup all your important information: contacts , memo...etc
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone: *#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
To
perform a master hard reset on your Nokia E63 cell phone reset. The
instructions do this is quite simple and effective on your Nokia E63
cell phone reset. Nokia reset. Master reset.you will need to: On your Nokia E63 Dial *#7370# and then enter your master reset code, by default it is 12345 NOTE:
Performing a Master reset on any Cell phone will master reset your
Nokia cell phone and erase the nokia phone reset completely including
contacts, pictures, videos etc. A hard reset on your Nokia cell phone
E63 will remove any viruses you may have on your Nokia E63 cell phone
master reset
This is a good way to reset your phone if it has any bugs in it that
the updates don't fix. Remember to save any contacts or important
pictures with the PC Suite. I didn't really know what PC suite was
before, but it's a program from Nokia that you install on your PC.
Using that and the data cable, you can backup important info or
settings on your phone.
You should install Samsung Kies, from that you can sync almost everything from you pc/phone. You can find it in the Samsung website, anyway, here's the link to the installer.
HI, THIS IS BECAUSE OF THE CORRUPTION IN SOFTWARE DDUE TO VIRUS.....RESET YOUR SETTING Soft Reset Enter the code *#7380#
Hard reset
OR To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
on/off + * + 3
hi here is the simpliest application that s attaching through this post
just transfer the file and install in phone memory and open the
application and the application show the unlock code which you forgoted
but be patient it take 10 to 20 minute to get code.
Note
on/off + * + 3
Had the same problem some time ago, but I found a solution: http://www.pcauthorities.com/how-to/outlook/export-your-windows-contacts-to-outlook-in-vista
Basically you can export your Windows contacts and import them in Microsoft Outlook.
