The HTC HD2 Smartphone may be affected due to virus or malware which is causing restarting and screen freezing problem. The virus or malware can infect the HTC HD2 Smartphone by the means of Bluetooth or PC Connectivity. To disinfect or remove the virus from the HTC HD2 Smartphone or from memory card it contains, scan your memory card using the anti virus installed in your machine.You can scan you memory card for antivirus using the Avira anti virus.Please download the anti virus from :
Install the software in your computer.Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card for viruses or malwares.
You don't need to install any special PC suite software when connecting your HTC HD2 to your computer. Just connect it using a USB cable and you will be ask to choose the type of USB Connection that you want (Active Sync, Disk Drive or Internet Sharing).
To know more about HTC HD2, you can open this FAQ section of HTC's website.
It seems that you have to update the software of HTC HD2 Smartphone. HTC provides Rom Upgrade in which it completely replaces the built - in software in the phone. Rom upgrade in the HTC HD2 Smartphone extends its features, imroves its performance which makes it easy to use.
Download the Rom Upgrade from the link provided below :
Rom upgradation completely erase the personal data and the customized settingsor any installed programs in the HTC HD2 Smartphone. Before Rom upgradation pleas backup all your data.
Please visit the below links to backup your data before upgradation :
http://www.htc.com/www/howto.aspx?p_id=297&id=191
http://www.htc.com/www/howto.aspx?p_id=297&id=187
During ROM upgrade, make sure that your phone battery is at least 50% charged. Automatic standby and hibernation are disabled in computer, and close all running programs. Do not disconnect your HTC HD2 Smartphone from your computer while the phone software is being updated. If
you disconnect the HTC HD2 Smartphonee during the software update, it may become
unusable.
install it and connect the phone with usb cable and run this app.
but if you have HD2 then,
for htc HD2 windows mobile : download the WMDC (windows mobile device center) for win7/vista PC or PC SYNC 4.5 for XP and install it to use your Windows phone 6.5 device.
for connect to computer you have to use HTC special program and you cant connect to another person by use bluetooth. these 2 problems are part of your cellphone
Start your bluetooth on PC and then in your HTC......I hope u have bluetooth software in your laptop......if not install it....try to search devices in ur laptop dont forget to keep ur HTC in visible mode. when ur laptop identifies the devices try connecting it.....best way that ur laptop gives a key n type the key on ur htc it will connect.....n u can strt data transfers easily......hope this helps......
Well for your information microsoft wm 7 so far is not coming to Htc hd2. But if you want to enable the 567MB Ram then you have to flash your phone with the After market cooked roms. You can go on xda-developers.com and click on the forums choose Htc hd2 and then rom developments. If you need any futher help let me know thanks.
