Same problem as Pramuk R.
Trying with different graphic everything is OK. When insert client's video - HD3470 /which also work on different machine/ - MB starts on on board video.
You have to change the BIOS settings for the Primary Graphics Adapter. Restart the system and go to BIOS Setting and Change the Primary Graphics Adaptor to [PCI Express]
(This item will switch the PCI Bus scanning order while searching for video card. It allows you to select the type of Primary VGA in case of multiple video controllers.)
The default value of this feature is [PCI]. Configuration options:
[PCI], [Onboard] and [PCI Express].
Asrock Alive NF7G-FullHD User Manual
Please refer to Page 46 of the above Manual
Hope it helps! Good Luck!
CreativeTECH
