My ipod nano got stucked in power-on. When i'm turning it on, the 'glasshour' icon appear, it just stucked there. Please help me. I tried to reset it by holding on to menu button and select button until the 'apple' icon appear, but it nothing happen, just the hourglass icon on screen.
Help me please
I have the hourglass icon on my ipod nano 8gb. It will do nothing.
you will need to reset your ipod this will not delete songs.
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press
and hold the Menu and Center (Select) buttons simultaneously until the
Apple logo appears, about 6 to 8 seconds. You may need to repeat this
step.
Tip: If you are having
difficulty resetting your iPod, set it on a flat surface. Make sure the
finger pressing the Select button is not touching any part of the click
wheel. Also make sure that you are pressing the Menu button toward the
outside of the click wheel, and not near the center. If the above
steps did not work, try connecting iPod to a power adapter and plug the
power adapter into an electrical outlet, or connect iPod to your
computer. Make sure the computer is turned on and isn't set to go to
sleep.
For Mac users
"When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems.
Reset, Retry, Restart, Reinstall , Restore
Reset your iPod.
Retry with a different USB or FireWire port.
Restart your computer and make sure you have the latest software updates installed.
Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web.
Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Still can't see your iPod?
Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Battery depleted?
If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging.
You're using USB instead of FireWire
If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only.
With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear:
If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub.
Your Mac is sleeping
Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod.
Your Mac doesn't meet iPod system requirements
Make sure that your Mac meets the iPod system requirements.
Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple.
You're missing some system sof
For Mac users
Reset your iPod.
Battery depleted?
For Mac users
Reset your iPod.
Battery depleted?
the hour glass just sits there and the background is black
the same problem for me the hourglass stays whatever i do.please help
