Question about Zebra GK420 Thermal Printer
Hi there i would like to know whether is there
Hi there i would like to know whether is there any possibility of printing on flat labels (not on roll) from Zebra Gk420t. I think it should not be possible, because the place where we insert hte media takes on ROLL only. Quick help appreciaed! thanks Abbas
    New Friend:
  • 22 Answers
You can use FAN-Fold Labels with the GK420 Printer. If you look at the back of the printer you should see a slot where you can feed the labels into the printer.
Hope that helps.
mikeo@acebarcode.com
Posted on Feb 22, 2011
SOURCE:
What are the settings for a TEC b-572 to make it print correctly, I am using win7 drivers
The printer knows nothing at all about labels, and isn't looking for any gap. I think you specified the wrong settings in whatever software you're printing the labels from - something in "Page layout" or "Format" or possibly "Printer Settings". You need to tell the computer software exactly what labels you're using, or exactly what your label specifications are.
Jul 30, 2014 | Toshiba TEC Office Equipment & Supplies
Not printing correctly
When you go into the software to prepare the label you should see buttons to select whether you want the label formatted from the left, right, or centered. Also, when you type the text onto the label you will probably see dotted lines around the label which can be moved slightly to help you get the print arranged on the label. Hope this helps!
Nov 12, 2013 | Dymo LabelWriter 330 Thermal Printer
Letra tag QX50 Faint printing. I replaced the batteries to no avail. Are ther other causes?
You need to check whether is ther any printer ribbon for this device, If any try replacing it and then it will print better.
Regards
Rudra.
Oct 11, 2010 | Dymo LetraTag QX50 Thermal Label Printer
After changing the print head and setting the Ohm resistance, the left side of the printed labels are faded. I adjusted both head pressure and slid them back and forth but I can't get it to print right....
It's very possible the printhead wasn't installed correctly. It's pretty easy to get it wrong, as there are two pins on the latched printhead bracket that have to fit into two holes on the printhead itself. You have to get the alignment of these pins and holes just perfect before you tighten the screw. You have to make sure the aluminum plate on the printhead is sitting flat against the printer's printhead bracket before you turn the screw on top of the bracket.
Sep 24, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Labels unexpectedly stop printing half way through a job
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Jun 02, 2009 | IBM Infoprint 6700 R40 Printer
Print adress labels on cannon mp160
Yes it is possible, Just have to make the appropiate adjustments to your printing software so that you will print on the sticker area. I have printed labels for like book without a problem. Just need the adecuate label sheets and configuration.
Jan 24, 2009 | Office Equipment & Supplies
Paper feed to far for labels
You should adjust the shutter as well to the size of the paper. Another thing is you can manually select the paper type under the printer settings. Go to Printers and Faxes > Properties of your default printer and manually select the paper type.
Sep 30, 2008 | Epson TM-L60II Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra GK420 Thermal Printer Logo
244 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
