Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster with broken pen
My daughter chewed on her leapster pen and the pointer came off.  Probably have to buy a whole new leapster...
  • 2 more comments
  • jstutes Sep 09, 2008
    I have two Leapsters that the pen is not responding to. They are both fully charged. Help!!!! JStutes
  • Anonymous Oct 29, 2008
    I have the same problem....who fixes these leapsters???....it will work with the arrow keys...it just does not work with the stylo!!
  • Anonymous Nov 08, 2008
    I have the same problem!!
  • crazywith2 Dec 02, 2008
    Sorry same problem here, except I don't know how the tip of my son's leapster pen came off....
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Posted on Dec 23, 2009
    New Friend:
The DS stylus is compatible with the leapster. You can get these in lots on eBay quite cheaply ( The ones from China etc are fine)
If the stylus wont work on the screen, the screen needs to be re-calibrated.
* step 1
  • Ensure that a cartridge is not inserted into the Leapster.
  • Step 2 Hold down the Hint button (labelled with a "?") while powering on the Leapster. This will bring up a menu of options.
  • Step 3 Press A ("Touch Calib") this will start the touch screen calibration process. "Starting touch calibration" will appear on the screen briefly followed by a black screen with a white cross in the upper left corner.
  • Step 4 Touch the cross that appears with the stylus pen. When you touch it, the cross will change to 4 dots and then a new cross will appear on the screen. Repeat this process for 5 crosses total - one in each corner and one in the middle.
  • Step 5 Turn the Leapster off and back on again. The touch screen should now be working again.
  • Or just go to the leapster website, go to F.A.Qs and look for the answer
    Posted on Aug 03, 2010
    I too have the same problem!!
    Posted on Nov 08, 2008
    SOURCE:
    Leapster 2 screen not working
    Hi
    This is a common problem for Leapster. The company has a repair program. Charges depend on warranty.
    May 11, 2010 | Leapster Learning System
    the screen maybe dirty try turing it off and cleaning it with a rag
    Mar 18, 2010 | Leapster Learning System
    My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
    Answer
    I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
    If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
    1) Ensure that a cartridge is not inserted
    2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
    3) When the LEAPSTER menu screen appears, press the A button
    4) Touch each of the crosshairs that appear with the stylus
    5) Restart unit
    Jan 30, 2010 | LeapFrog Leapster Learning Game System
    The touch pen doesn't work
    Answer
    5) Restart unit
    Nov 28, 2009 | LeapFrog LeapSter L-Max Console
    Leapster pen not working
    1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
    May 12, 2009 | Leapster Learning System
    I need to order a new pen for Leap Frog's Junior Explorer Globe
    Call their Consumer Services at 1-800-701-5327. They will be able to help you order a new one.
    Dec 29, 2008 | LeapFrog Leapster Electronic Book:...
    The pen won't work on my daughter's leapster
    Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
    Leapster
    I found this on an Ebay guide...
    "FIRST! The pen is not electronic AT ALL! If the screen does not seem to be working with your stylus pen (for instance, you click one part of the screen and it clicks a totally different part), you may need to calibrate the screen! Put a cartridge in, turn the system on, and when the sign in screen comes up, press the HOME, HINT, and B buttons at the same time. When the screen changes, press the A button. Follow the directions.
    If you need a replacement pen, with the cord attached, follow the instructions:
    Send $5.00 in check or money order (to cover shipping and handling charges) to
    LeapFrog Customer Service
    Leapster Replacement Stylus
    563 North Fairview Street
    Santa Ana, CA 92703
    Please note that this is supposed to be for pens that are lost or damaged ONLY."
    Sep 23, 2008 | LeapFrog Leapster Educational Game: Disney...
    Need parts
    Call consumer support at 0800 169 5435
    for instructions on how to detach the stylus
    from the L-MAX unit. They will assist you in ordering a replacement stylus.
    Oct 26, 2007 | Video Game Consoles & Games
    LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
    3,799 people viewed this question
    Top LeapFrog Computers & Internet Experts
    kas8970
    Level 1 Expert
    Alun Cox
    k24674
    Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
