To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
You only have a couple of places the water can go. Typically most flapper toilets need a new seat where the flapper fits because the seat is worn. Go to your nearest hardware store and buy the repair kit with the new flapper seat. This simply epoxies to the existing seat and creates a new flat seal surface. the other places are bad float or refill level guage. And of course the first thing is do you have water on the floor.
The flapper is secured with a rubber band. The rubber band must be removed from the flapper for the toilet to function properly. Please check the flush valve prior to installation and if the rubber band is present, simply cut it and remove it.
