If the touch screen of the Camcorder is not working, please
follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Hi having problem setting date ,month ,time on - shajanrs_49.jpgoads/images/shajanrs_Hi having problem setting date ,month ,time on - shajanrs_50.jpgajanrs_49.jpg" class="h_mi" />
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15
seconds, turn the Power switch to OFF position and then reinsert the battery
pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
