Dryers Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire, blank, red small wires. Found a large red wire and a green wire loose and I do not know where they go, timer does not turn then the dryer just cut off while low heat. Where does the 2 wires connect?
Sal De
Level 3:
  • Dryers Master 2,699 Answers
  • Posted on Feb 22, 2011
Sal  De
Dryers Master
Level 3:
Answers
2699
Questions
0
Helped
1003152
Points
8029
The green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
1helpful
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 • Dryers
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 • Dryers
Swap power cord
You should call an electrician as if you cause a fire or damage your insurance company won't cover you. Also you have to get a cord with the "L" shaped spade at the top which is for a dryer and a "straight" spade is for a oven.
2answers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
1helpful
2answers
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Wiring wiring the dryer plug on a hotpoint dryer
First thing do you have a 3 or 4 prone cord?
For 3 prong, when looking at block where cord attaches you have a left, center, and right screws, attach just like cord 3 wires, left on left, center on center, right on right. The only thing different with a 4 prone is you have a ground wire which grounds to ground screw on dryer.
2answers
Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Jun 12, 2009 • Dryers
Need to hook up new plug
Red on one side of terminal block, white in middle, red on other side. The green is attached to outside using screw to to top left of terminal block compartment on outside of cabinet. Hope this helps!
1helpful
2answers
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Top Dryers Experts
john h
