Timex 40131 Wristwatch Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help please...I have a timex ironman watch, but appear to have lost my chrono. When i press 'mode' it alternates from time to timer, to occasn. I seem to have lost the chrono option (*sob*)
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Feb 23, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767737
Points
24828
My timex ironman 30 lap flix will not move to the chrono mode
From the time mode, just press mode button once and the word "chrono" will appear.
1helpful
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
I have a timex w-209 have lost the the timer function
Maybe the battery is weak? Does it have a light? If the battery is failing then the light will be weak or wont work at all. You can check
www.timex.com for your watch, they might have a downloadable manual.
Good Luck!
8helpful
I press MODE button & get timer, occasa, alm1,2,3 but no CHRONO!!! How do I get to use the chronograph?
Setting Time after setting it, shows other type of settings 24/12 hrs, beep, chime and it shows Chrono where you can display or not. :)
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
20helpful
Timex Expedition sports watch - how to view lap times?
I ran into the same problem w/ my new Timex Expedition. I emailed their help desk and they said that the Expedition models do not have lap memory feature. You need an IronMan watch to get lap recall. Wish I knew that before getting this Expedition watch...
Brian
1helpful
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
