This question is too old; however, assuming someone with similar question can be informed of the same.
Most cameras (brand/model) will require an associate software for use in tether mode. For Fuji, it would be Fuji Camera Remote application - Fuji-hyper Utility software, Canon EOS - the EOS Utility etc. Without the software, your camera becomes a SD card holder when it is connected to a computer. You can't do anything with it.
(There are exceptions though - for instance, a Sony Cyber shot DSC W30/ W40 future a AV out jack that can project AV on the computer or TV)
SOURCE: Fuji s6500 different lenses
hi kelize, you were looking for a "telephoto" lens for your "fujifinepix s6500fd" and so was i , i have found and ordered a "raynox dcr 2025" with adapter for mine, 2x2 magnification, dont know if i can tell you where on the post , but i will and hope they put it up for you, (advertising! some forums dont like it) it is www.digitalfunstuff.com.au hope this helps, riki.
SOURCE: softwear for finepix camera
The A202 is a European model and they do not have updates for Vista that I could find. You can however find the updater program for the FinePix software that includes Vista. http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportSoftwareContent.jsp?dbid=864214&prodcat=644675&sscucatid=664260
SOURCE: fuji s20 pro failed ccd,
A little research shows me that Fuji has undergone an extensive repair recall for several Fuji models because of failed CCDs. My S20 Pro just lost it's ccd as well. For some reason it looks like the S20 was not covered in the free repair offer by Fuji. Has anyone else had a CCD problem with their S20
SOURCE: fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac. I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
