Re: Im not getting a HD through my component cables
Im using my xbox 360 trying to get it to 720P through component cables but i get a black screen with sound although my ps3 is hooked up through HDMI on 720p without a problem
in order to send hd video to your HDTV, you will need to use a hdmi cable. If you are planning to use component cables make sure you have component output from camcorder..still it is not HD.
If you have the cable that is both component and a regular a/v cable, make sure that the switch is on regular tv and not hd, then ste the hd settings to what your tv can handle and then turn it back if you need to.
This particular television puts you in a tough bind - you can use Component cables in AV1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot, but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot (I'm assuming, perhaps incorrectly, that your actual model # is not really a 50P8341, which has no V/H Sync slot).
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
For connections of audio, so that you can hear all tv audio through the surround system, connect either an optical audio cable or red & white analog audio cables from the tv to the home theater. If you are using optical audio, there is a plug on back of tv labeled for digital audio output and an input on the surround sound system. If you plan on using analog red and white, use the PROG OUT red and white output jacks on the back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or Component cables. HDMI is the cable that will provided 1080p signal (the best HD signal), but if the source does not output 1080p, then your tv will not display 1080p. Most cable boxes output at 1080i or 720p when on HD stations. This signal still provides great picture quality, but HDMI is not needed to get these HD signals. You can use component cables for your cable box and the DVD player output to the tv for video. HDMI might give you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the tv (component or hdmi). Also from the home theater system to the tv using hdmi or the video cables from component (red, blue, & green cables).
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
I am not finding anything on the net about being able to upgrade it but the HD in the model # stands for high def but the tv is old enough that it may not go up as high as 1080 most likely just 480i or p which can be achieved with an s-video or might be 720 with the R/B/G connector or a DVI connector, you can look for converting cables on ebay
what type of equipment are you connecting? What cables are you using? MM85
