Posted on Feb 21, 2011
I inserted a new battery to Sharp EL 6092 ,it tell me Data problem,please reset.After reset tell me reset ok?Then i press any button it tell me again Data problem. I dont understand
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
826
Points
11
First press the reset button then when the display says "RESET OK ?" press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter. Display will then say "BUSY". Reset is then complete.
Sharp el 6710s
im still trying to figure out why my hp 4620 doesn't print or copy
4helpful
How to reset Sharp el 6710s?
Hi! Today I had the same problem, after you click on reset, the screen will show you RESET OK?, there you just need to press 2nd and ENTER key, the screen will show the word BUSY for a while, and then it will be reset; you'll be prompted to enter your business data and you're done.
1helpful
How do you reset a Sharp Scientific Calculator Model EL-5103 and is a manual available? Old but still working.
Reset instructions from the Sharp Instruction Manual include removing the batteries, re-installing them, then pressing the [OFF], [ON], [2nd F], and [CL] keys in that order. This will erase any saved formulas and data.reset-sharp-scientific-calculator-oaktevzxqwobflsbvgxv12ee-1-0.jpg
Hi I have a Sharp Elsimate EL331A calculator. How do I programme in the new 20% VAT rate, please?
Press the red [C-CE] button twice, then the yellow [+TAX] button.
Then type in the Tax percentage. Press [+TAX] again and then the [C-CE] twice again.
This works for the EL-331A Calculator.
10helpful
Set the date & time
I'm going to quote dsteele04 on this one (he is a user of this site).
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
182helpful
Sharp EL-1801P III Calculator Setting Time & Date
~DLS
2answers
Pictures only on sports mode
Try resetting to factory settings - here's how
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
Now try - it could have fixed it. If not, keep turning the dial back and forth, and see if it jogs the camera's operating system. Try switching on and off. You should know, by the way, that the on/off switch doesn't really switch the power off - it tells the internal computer chips that you want the camera to switch off, and then the program closes it down enough to not respond until you either switch it on again, or take the battery out and re-insert it, when it will indicate a red light on the back of the camera to show the battery has made connection, then you switch on again; good luck - if not, phone Canon in your area
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
