Hi, You can buy the battery at any mp3 player accessory store around your area, or you can other on line through eBay.com and Amazon.com.
How to Change the Battery in a Dell DJ-20..
The DJ is an MP3 player developed by the Dell computer company. Like any other battery-powered electronic device, the battery will likely give out and stop working at some point. If this happens to a Dell DJ, the two main options for fixing it are to send it to Dell to have the battery replaced, or do it yourself. You can save a great deal of time and money by replacing your own Dell DJ battery.
Things You'll Need:
* Micro screwdriver set
* Tweezers
Instructions
Hold the Dell DJ upside down so you have a clear view of the bottom.
Wedge a flat-head micro screwdriver in between the black plastic piece and the USB port on the bottom of the DJ. Pry the plastic piece off and set it aside. You should now see four tiny screws on the bottom of the DJ.
Remove the four screws with a micro Phillips-head screwdriver. Set the screws aside in a safe place.
Pull the metal plate out that was held in by the screws. You may need to use a screwdriver to help pry it out. Once removed, you will have access to the inside of the DJ.
Locate the small red cable with a white plug on the inside of the DJ. Carefully pull the plug out. If you cannot grab the plug with your fingers, use a pair of tweezers to do so.
Grab the battery with a pair of tweezers and pull it out. The battery is the thin rectangular piece that the red cable is attached to.
Insert a new battery where the old one was. Plug the battery into the motherboard where the first battery was plugged.
Reattach the metal plate on the DJ with the four tiny screws. Snap the black plastic piece back on to finish the job.
