Hi onlyrovelyn, Go to this Link: www.dfa.gov.ph or http://www.passport.com.ph/set-appointment
Kindly follow the step before you proceed and save the requirements need.
Hope this helps.
Thank you for using Fixya
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit.
Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
To my knowledge and depending on what board your Cobra 29GTL used, R46 is 47ohms dropping resistor after the switched 12V. Its output is then filtered by C20, 100uF/16V. While it is true that a shorted C20 would burnout R46, the issue is most likely a shorted FET2 (P/N 2SK104H). Should FET2 proved to be shorted, then it is very possible also that inductor/coil near FET2 is defective (LT-A108?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
