Krups Nespresso Essenza XN 2009 Espresso Machine Logo
Posted on Feb 21, 2011
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 15, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1739
Points
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Anonymous
Level 1:
New Friend:
  • Posted on Aug 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1739
Points
I have just got the same problem - however, if there's no capsule in the machine, the pump doesn't cut out. I've never descaled it so it maybe that the 'back pressure is triggering the safety switch on the pump. I'm going to buy some descaler and see whether that solves the problem.
My Nescaf? Dolce Gusto coffee maker won’t work and just keeps flashing green, why? And how could I fix it?
actually I prefer my Bunn coffee maker . with practice you can make small brews and ground coffee is less expensive than pods .of which I have tasted many and like none of them
1helpful
Just descaled my 2 year old SENSEO machine. Everything working well EXCEPT only coloured water comes out into the cup. tried with several different pods.
Hello, Chris -
The problem may lie with the small tube which pokes a hole in the coffee pod. The tube may be blocked by bits of coffee grounds or loosened scale.
You will need to remove the holder into which a pod is to be inserted.
You then should be able to snap the holder apart.
Then, you should find the small tube which pokes a hole in the pod for brewing.
Use an unbent paper clip to try to gently dislodge anything that may be blocking the tube. Do this over the kitchen sink while water runs over the tube.
There are also tubes which inject water into the pod. Find them and use the paper clip to dislodge any clogs.
Reassemble the coffee maker.
Without inserting a pod, run water through the machine in the brewing cycle - 3 separate times. Place a glass or metal measuring cup to collect the water. Notice if any debris comes out with the "brewed" water.
Then, insert a pod into the machine and run the brew cycle to determine if the coffee is properly brewed.
If the coffee still isn't brewed properly, I suggest you contact Senseo (owned by Philips) Customer Service by telephone. I have no idea where you live, so I cannot provide you with the correct telephone number to call.
I am answering from the USA.
Best wishes.
2answers
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Won't brew espresso
I had the same problem and fixed by replacing the pressure valves which are two units in series.
Second hand dolce gusto coffee machine
Hi Jo!
The website for this product is here. Just under the top picture of the machine is a link to download the manual if you didn't get it when you bought the machine. There's a customer service number at the back of the manual. They should be able to tell you how to get any parts you need.
Looks like a pretty neat machine. I hope you get it brewing soon!
3helpful
We have a Krups KP1010 Pod Brewing machine. The brew button is stuck and is blinking, but will not brew coffee. How can I reset?
For those of you having problems with your KRUPS KP1010 Pod brewer stopping brewing in mid-cycle and then having the blue led power light blink rapidly, I have found the cause of the problem as well as a solution.
I have a Krups KP1010 pod brewer at home that is nearly 2 years old and has NEVER had a problem. Having enjoyed it’s continued great performance, when a small group (8 people) of people in my office decided to go "POD", we pooled our money to purchase the Krups.
After 8 months of moderate, not heavy, use, this problem developed. It got worse and worse, so bad that it would stop almost instantly after pressing the brew button. Sometimes it would work as normal, and other times, we found that if you applied pressure to the top lid, it would work completely.
This started me thinking that there must be a sensor switch inside to detect when the lid is open. This suspicion was backed up by the fact that when the Pod brewer was ON, but IDEL, if you open the lid, the blue light would and should blink.
Here is what I did to fix it.
If you are at all handy with taking things apart and making small minor repairs, this problem can be easily fixed rather quickly.
There is a total of 8 screws to remove. Four are located at the bottom of the unit and are the same size. Two more are located under the water tank reservoir, so you will have to remove the water tank to access them. These two screws are the same size at the four that you removed from the bottom of the unit. The last two screws are located at the top of the tank, BEHIND the lid, but can easily be seen when you remove the water tank. Turn the KP1010 around so that the tank is facing you. When you have the tank removed, look at the top area of the body of the pod brewer. These are the last two screws that you will have to remove. They are NOT the same size as the other six, and you will likely need a smaller jewelers sized Philips screw driver to remove them.
Once you get the back of the unit off, with the water tank side of the brewer facing you (coffee pod area facing AWAY from you), look in the upper right corner. Unlock the latch at the front of the brewer. Now while looking in through the back water tank area, in the upper right corner, gently raise and lower the brewer lid. You will notice that there is a LID SENSOR SWITCH. The switch is defective and, like a washing machine, when the lid is OPENED, the switch cuts the circuit (power) to the brewer, the same as when the washing machine stops when you open the lid.
The Fix: While Pod brewer is UNPLUGGED, gently grasp one of the two connector wires attached to the lid sensor switch. BE SURE TO GRAB IT FROM THE METAL CONNECTOR AND NOT THE BLACK WIRE ITSELF AS YOU MAY PULL THE WIRE AWAY FROM THE METAL CONNECTOR AND WHILE IT IS STILL REPAIRABLE AT THIS POINT, IT WILL BE MUCH MORE TIME AND SKILL CONSUMING.
Once you have removed the wire and it’s metal connector from the lid sensor switch, repeat this process with the OTHER black wire connected to the lid sensor switch.
(I tested this fix by at FIRST using basic tape) The fix for bypassing the lid sensor switch is to connect both black wires together. I initially used basic tape to ensure that my suspected cause of this problem would be fixed by my suspected solution. I then brewed 3 tanks of water back to back and the "stop brewing, rapidly flashing blue light" problem NEVER appeared. FIXED!
Now to be a bit more professional about it……… I removed the tape and soldered the metal connectors of both black wires together, and then wrapped with electrical tape. You COULD just wrap them together snugly with electrical tape if your NOT into soldering, but for the best, most secure connection, SOLDERING is the best option as there is no chance of vibration causing the black wire metal contacts from intermittently losing contact with each other. Again, if you are un-comfortable with soldering, at least try wrapping the wires snugly together with electrical tape.
Today our Krups KP1010 brewed flawlessly all day. The ONE downside to consider in this procedure is that now after having this "fix" performed, should you leave the lid of the brewer OPEN and start a brew cycle, the brewer WILL operate and shoot hot water & steam out everywhere. However, for those of you that own this brewer, you should know that having the lid open nearly completely obstructs you from easily reaching the brew button AND, what moron would leave the lid open and try to make coffee? If someone does that, they DESERVE to get burned!!
Best of Luck!!
Ed
1helpful
2answers
KP1010 Blue light blink really fast
Best of Luck!!
Ed
Lid won't open - coffee won't
Best of Luck!!
Ed
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
