SOURCE: my laptop is c700 compaq presario. Its touchpad is
try to install the driver for touchpad, if the same check the hardware.. or try return to vista if working properly it means some problem for os xp.. because you downgrade the system...
hp company advice all user to do not downgrade but we can we use xp. the problem only not compatible some drivers
thanls
SOURCE: HP Presario c700, power on automatically.
If this is a new issue you can revert, or go back in time when the computer was working fine my using 'system restore'
To use System Restore to restore Windows XP to a previous state, follow these steps:
If
you successfully restored your computer to a previous state, and the
computer is performing as it should be, you are finished.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
Also there is a setting under 'power options' on the advanced tab that controls how the pc shuts down when the button is pressed, go and check to see how that setting it configured, by clicking on the drop down button
SOURCE: synaptic touchpad enhancement is not working
You will need to activate it in the bios settings, Enter the bios with your F key, have a look through the peripherals or similar and ensure that touchpad is "active"
