Since it's an IDE hard disk, you'll have to setup disk jumpers, please check the following image:
If you want more information please see the installation guide at the following link:
http://www.hitachigst.com/tech/techlib.nsf/techdocs/4DD4DCCA11DE5EB186256D6A0061C8A8/$file/Installposter.pdf
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
single or master :::::
master with slave ::|::
slave :::|:
note the plastic jumper is | located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
