Error message showing. The light on the scanner is not working. Is this likely to be the actual lamp / florescent tube and if so is it something I can replace myself.
Thanks
George.
If the lamp is not working their are two main possibilities. The first is that the lamp has failed and needs to be replaced. Buying a replacement MAY be dearer than buying a new machine - you will have to price the parts locally.
The second option is that the controller board for the scanner has gone. Again this could be an expensive part, but contact a local repair center or parts supplier to price the bits.
If you are successfull in getting the parts (you may buy a faulty machine off ebay with good scanner and bad printer to strip parts from) then this service manual will help you get to the parts you need:
http://www.tradebit.com/filedetail.php/814420-Documents-eBooks-Technical
same problem I have. I will try to replace the lamp and if that works will post message
have the same problem, no light on,scanner not working,
mine just packed in ,same problem, anyone know how to get into it to change lamp
