SOURCE: Pioneer xm radio suddenly stopped playing
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
SOURCE: Pioneer Inno - Powers on, great signal - but audio or pad data!
I'm assuming the power button it not in 'hold' position, and you have the volume turned up, and/or on the correct frequency with the adjoining radio?
SOURCE: my pioneer inno xm receiver is stuck on channel 1
Are you sure you gave them the correct radio id number?
Let us know if and when your problem has been solved.
SOURCE: pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
