SOURCE: movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
SOURCE: Sony DAV-BC150
Sounds like your TV's sound output isn't working. Check all the connections and if that doesn't do it, try hooking up some other sound system to the TV to check that it is working properly.
SOURCE: DAV-FC8
I had the same problem for a time and there is toggle with the remote which you turn on or off...just read the manual and you will find the fhis fix
SOURCE: CAN I USE HDMI CABLE
Yes. This is what you should do. Connect the Bluray players HDMI cable directly to your TV, then use an optical cable (usually around $20-40) to go from the Bluray player to the surround system. You will then need to enter the menu of the Bluray player and set up the Audio to be run through the Optical output instead of the HDMI. Problem solved!
SOURCE: I recently purchased the DAV-DZ810
Please check the connections TV - o/p and DZ810 - I/P ports..!!
