Unless you see a large hex head socket to remove on the top of the water heater, many
anode rods are built onto the hot side nipple. They are almost the length of the water heater.
Hopefully you have room to remove it if this is the case. If you see a hex nut that is silver
gray on top, then shut off cold water to the heater. Release some hot water at a tap to relieve
pressure on the tank or drain some out at the bottom which is better. Make sure power is
off to unit first or gas is off . Unscrew nut or nipple counterclockwise to remove. Best to
remove with a socket wrench or box wrench if it's a nut and a good pipe wrench if it's
on the nipple. Several light taps with a hammer if necessary on the handle of the
wrench or pipe wrench should help. Hopefully the nipple has a removable flex line if
it's located there. (Remember it's on the hot side and should be marked on the top
of the heater).
