Toshiba Satellite A305D-S6848 Notebook Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi! I have a laptop repair Satellite A305D-s6848. I turn the laptop fan spins, no display, it can not turn off power button. Can there be a reason for the bios? Please help Hdd drive is removed, RAM is smooth, the processor is ok
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Feb 20, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
527841
Points
7608
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
1helpful
Hi! I have a Toshiba Satellite A305D-S6848 and can't find the number lock button. Can you help?
Hi.
That particular Toshiba laptop model doesn't have a number lock key. You have to hold down FN and then use the letter keys with numbers printed on them.
Regards.
11helpful
3answers
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
1helpful
My Toshiba A305D-S6848 LCD Screen is crack-where can I get it replace for a reasonable price.
Try www.ebay.com they have lots of LCD screen for your laptop. I always find that ebay is cheaper than buying parts from the service center or local repair shop.
I was working on my laptop (internet browsing), I let my room, came back 10 minutes later and my laptop was completely shut off. It will not turn back , no lights, no nothing. PLEASE HELP! Toshiba...
Unplug and take out the battery for a few.
Put battery back in, plug it back in and see if it will power back up.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
2answers
Toshiba Satellite A305D-S6848 HAS NO POWER. NO LIGHTS COME ON AND I PLUGGED THE POWER CORD INTO ANOTHER TOSHIBA AND IT WORKS. NOT A POWER CORD PROBLEM. NO FANS RUN OR ANYTHING WHEN I HIT THE POWER BUTTON....
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
1helpful
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Toshiba Satellite A305D-S6848 will not keep charging when it is plugged in
just update the BIOS it will help or else check with the physical connection if u find any damage contact the vendor..
1helpful
2answers
I have a Toshiba Satellite A305D-S6848 For a
I. Reinstall the driver:
Right click on My Computer (XP)/Computer (Vista) icon on the Desktop, click on Properties, the on Devices, then in the devices list look for your camera (you might have to open the branches to see it). You may find it under a branch named ‘Image Processing Devices’ or something similar (I don’t know the exact wording, because my system is not English).
Select your camera entry and then double click on it. Under the Driver tab, select Update driver and choose Reinstall Driver and then the second option ‘Look for Device Software in the Computer”.
II. If that doesn't solve your problem, download and install the most update driver from TOSHIBA support pages:
  1. Start here: http://downloads.sourceforge.net/sevenzip/7z465.exe
  2. Click on 'Download'
  3. Select your product Category (Laptops), Family (Satellite) and Model (A305D-S6848) and press GO
  4. Refine your search by selecting your computer system OS and by selecting 'Multimedia' in the Category list box.
  5. Download the camera utility.
  6. Install it
1helpful
2answers
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
